Replacement battery for 1996 PKE Key Fob?
macvette
Yorkville, IL, USA
1996 Polo Green Coupe, LT1, Auto
I'm having trouble finding a replacement battery for my PKE key fob. I've found batteries that say CR2450, but they do not fit properly in the key fob. The edge of the battery needs to have a slight depression to fit under a small plastic piece in the battery compartment. Has anyone else encountered this problem? The existing battery is made by Sanyo.
Thanks,
Jim
Had the same problem. Solved by inserting the battery, first in the 4 o"clock position & then pushing it under the tang.
That's how I tried it, too. I was afraid that if I pressed down too hard that plastic piece would break off. The OEM battery does not appear to put much force on that tang. Is it flexible?
I changed both of mine with no problem, but you know how that goes????
:CRASH :CRASH :CRASH
Try it both ways.......
macvette,
Sorry about the broken link to Batteries Plus, try the new link below, this one should work.
When I've replaced my key fob batteries, I take the spent battery along so they can match them up.
http://www.batteriesplus.com/
B17Crew
Hi
Bat Plus site is nice , but search feature is not available.
Anyone got a hotlink to the ACTUAL battery?
I am in the middle of moving to the new house and have limited internet time.
Plus will be without web for a week after today.
Radio Shack no longer stocks the 2450.
Someone drop me an email with a source, please.
Rain
Rain said:
Hi
Rain
http://www.batteriesplus.com/Product/lithiumcoin.html
Jim - Had same problem. I bought the "proper" battery at Eckard's - Didn't fit - Called the local Chevy dealer - they had one for less than Eckard's - and it FIT!!! Go figure. Later, JPC
