Saw you have a 94 from your other post.
This info from Corvette Fever, 12/01
The SRC light can be turned off & the system disabled by disconnecting the SRC module.
The SRC is located in the compartment behind the drivers seat. There is a 7mm screw under the carpet.
The SRC module is a black plastic box, 2 inches by 3 inches, & about 1 inch thick on the bulkhead behind the drivers side seat in the compartment. The SRC is fastened to the bulkhead by 2 7mm screws. The module has a 32 position connector with 27 wires. Locate & disconnect the32 position
wire connector. Once disconnected
the SRC is disabled & the light will no longer be on.
This will not effect any other system or illuminate other warning lights.
The article specifically mention a 92, but am pretty sure they are similiar.
