jrclark32
I have a '92 coupe with about 85k on it that I've owned for a little over a year. It hasn't given me any problems at all, until about a week ago when I was driving through town and it just completely dropped dead. I cranked on it a few times and it acted like it was trying to fire, but wouldn't start.
I was sitting at a stoplight at the time, and after a couple minutes gave up and was looking for a place to push it out of the way... I tried it one more time, and it fired on the first crank and ran perfectly.... for about 10 miles.
I was humming down the interstate doing 70, trying to make it home when it died again. I noticed this time, that about 4 seconds before the engine quit that the "Service ASR" light came on.
This time I had to wait about 15 minutes before it would restart, and this repeated itself about 4 more times before I finally ended up pushing the last 1/4 mile to the driveway -- ever time, that "Service ASR" popped up seconds before it died.
I've pulled codes (as described by http://www.c4guru.com/articles/CCMCodePull.pdf), and under the 9. module, I'm getting:
H62
H65
H74
These codes are listed as EBCS error codes:
62 - Tachometer Data Error
65 - Adjuster Assembly Error
74 - Low Voltage
I've found that if I disconnect the battery for a few minutes, that it will reset and then start and run for a short while before the problem repeats itself -- which it does every time.
Does anybody have any experience dealing with this -- or any ideas where to start? Is it possible to bypass/eliminate the ASR system (I never use it anyway)?
Thanks!
H62
H65
H74
74 - Low Voltage
Thanks!
