Are you talking about the rear output shaft seal on the trans? If so, I'm in the same boat as you. Been replaced two or three times now and starts to leak again after a few months. I even had the yoke looked at. Maybe it's time for a new one but I understand they are extremely hard to find as they are no longer made.have replaced it twice and it keeps leaking. a friend said the shaft might be worn. any ideas or tricks anyone can suggest or does the shaft need replacing. the car is a 79 w/th350.
