ttt123
- Joined
- Aug 26, 2014
- Messages
- 94
- Location
- michigan
- Corvette
- 1994 base,metallic blue with custom wide body
Well like the title says, started small and as usual its turned into more. I have two threads going. one for the rear-end upgrade I'm doing and one for the wide body I made.. seems a little selfish to have a few threads going for the same car so I'm just going to post all my updates and complete build in this thread. if you want a recap of what I've done so far(I'll post a couple pics from the two other threads in here) you can check the links otherwise stay tuned to see where this goes
http://forums.corvetteforum.com/c4-t...nance-etc.html
http://forums.corvetteforum.com/c4-g...or-my-car.html
with the car being pulled apart as far as it was.... I just kept going and decided to repaint(sapphire metallic blue, already had a gallon in my barn screaming for me to use it) and rebuild the motor with some tasteful upgrades. engine will get new cam, worked heads and intake(ported and bigger valves) pcm tune, long tube headers and electric water pump 3:54 gears, shift kit etc..... oh and air foil for an extra 15hp
i've started putting the rear end back in and working on painting the rest of the car.
otfl it did look like a nice paint job when i bought the vette but they obviously didn't take the time to sand and pre-wash before they painted this corvette. i fix and make good
oohoo: i like the silver against the black paint on the underbody
