Had a bad starter about 4 months ago so went to Autozone and bought a starter. Put the starter on and it worked and sounded fine for the first 3 starts. Then the starter started making a higher pitched noise while cranking. The starter would still crank the engine until it started but the noise didn't sound right.
Took that starter back (under warrenty) replaced it with another starter....same problem.
Took that starter back put on an AC Delco starter...same problem.
Took that starter back and put on a Powermaster XS Torque capable of turning over an 18.1:1 compression engine. Same problem.
Any ideas of whats going on here? Wiring stayed the same on all the starters and the original starter I had on the car worked fine since I've owned the car until it crapped out.
