87 Twin Turbo
New member
Hey guys,
It's been awhile since I last posted here. Looking forward to the reunion and the prime parking location for us.
I have been having a problem with the car. I think I have a problem with the solenoid or the starter, or possibly even the ground wire. Come to think of it, it might possibly be the neutral safety switch. My question...how does one go about gaining access to the starter? With the oil lines and the metal tube running from the engine to the catalytic converter in the way, does one have to remove this or what? Can access be gained by taking off the front wheel and the plastic splash guard?
My problem is, when I turn the key sometimes the engine does not turn over. Turn the key again and it will start-sometimes. When it does turn over, the starter turns as normal. Can't see anything from the top as to where the grounding wire is attached to the frame or engine.
If it should be the starter, I have been told to use the smaller high torque starter. Any thoughts on this other than it would not be considered an "orginal replacement"?
Hoping it might be a simple fix, but with these cars, nothing is simple. Any suggestions and input would be soooooo appreciated.
Jack
Jack
