steering post
pizza3260
nj
73 350 coupe
just replaced my steering post to tilt/tele, ignation busser will not shut off, what's the problem.
thanks
tom
navy2kcoupe
West Central FL and SE Mass.
2000 Navy Blue Coupe A4 Z51
Did you replace the ignition switch when you did the swap? Sounds to me like you've got something grounded that shouldn't be, like a pinched wire, or a miss-plugged connector.
Andy
duke94
Ann Arbor, MI
71' convert and 78' both Red
There is also a small finger type switch the key actuates behind the ignition lock. Could be damaged so it makes contact all the time.
KOPBET
Tulsey Town
'73 Silver LS4 4 speed
Possibly the ignition key warning buzzer switch behind the turn signal switch. Mine had a crack in it causing the switch to be in contact all the time turning on the buzzer.
