Spiderman
I recently replaced my factory stereo with an aftermarket CD player and I was aware that I would be getting a SYS warning signal from the ECM. This is due to the LCD panel and the dimmer connections no longer being hooked up on the factory harness. I was fortunate enough to obtain info (thanks to the CAC
) about tricking the computer by putting resistors in place of the circuit. (It's a few replies down on this thread Here.) I'm pretty sure that will work but if I reset the ECM by pulling the fuse do you think it may clear the code without having to go through all of that?
Just Curious.
Spiderman
Just Curious.
Spiderman
