M
Mark S.
Hib, I've read many of your articles and I remember you describing the oil change procedure on the '97 C5. This past weekend I did my first oil/filter on my '01 C5 Coupe - 1,300 miles ( I thoroughly drained every bit of oil out by lifting the rear, etc.). I then re-filled with the 6.5 qt capacity, took her for a spin and then checked the oil level. After letting her sit for approx 20 minutes I checked the level and found that I was about a half quart low. There are many '01 owners posting (in other forums) that it now takes 7 qts to achieve a "full" refill on the dipstick. This doesn't make sense since most of the '97-'00 owners are saying that 6.5 qts is "full" on their dipsticks. I know that GM did a dipstick and dipstick configuration change on the '01 model (perhaps that's the culprit). I went ahead and added an additional eighth of a quart last night and the level on the dipstick now reads a quarter of a quart low. Did GM make any changes to the oil pan capacity from '00 to '01? I don't think so. I do know that I checked my dipstick on my C5 the day I picked up from the dealership and the oil was at the "full" mark. Maybe the dealer topped it off. But it seems that the factory is filling the LS1 with 7 qts instead of the rated 6.5 capacity. Do you have any info on what's going on here? And is adding an additonal half quart of oil going to cause problems in the future? Thanks!!
(I just realized that this should have been posted in the 1997-2002 Technical Discussion section...oh, well)
