- Thread starter
- #41
SebringBill
Bingo!
After Hurricane Andrew in 1992 the building codes became much more stringent. Now FL (after the Miami-Dade lead) codes are among the toughest in the country.
The addition is being built to withstand 130 mph winds. You're right about lift, but don't forget about shear. There are 6 of these Simpson HTT22 tension ties spread between the two main load-bearing frame walls; the bolt is drilled 10" down, epoxied in place and 32 16p nails attach the tie to the 2x6 vertical.
In addition, there are 10" "Titen" (big azz) bolts screwed into the slab every 24" to hold the rest of the wall down.
Every crew that's worked here has commented that they know where the hurricane party will be - that garage that ain't going anywhere!
