Those with Modified Engines and Original Carb
It should, but I make no guarantees. Most of the mods only effect WOT performance, unless you are running a highly modified engine that might need idle circuit modification. In that case, I doubt you are concerned about smog inspection anyway.
Hello Chris,
My carb is leaking fuel past the little bolts (with epoxy) I installed earlier. Are you using special fuel resistant epoxy or not? Now I have all winter to fix the problem :)
Thanks,
Greetings Peter
Putting epoxy on leaking plugs is like smearing tar on a leaking roof. It might work for a while, but it is bound to leak again.
When I do this repair, I combine it with opening the fuel passages for higher fuel flow potential. I remove the old pressed in plugs, precision drill (open) the fuel passages and tap (thread) the holes. I then cut a about a 1/4" long piece of stainless steel threaded rod, and slot the end of it for a flat head screwdriver. I then coat the threads with epoxy (JB Weld or equivalent) and screw them into the holes to make a permanently sealed repair.
God bless, Sensei
God bless, Sensei
Did the same thing but two plugs (or rods) are leaking. But I'll see what the problem is :)
Looks like JB weld works alot better then the epoxy I used within the treads. Found somebody here in Holland who sells it so I'm going to use that. Thanks! :)
Greetings Peter
Very interested, PM sent.
EDIT...
Aparently my PMs arent sending... What I wrote was -
Hi,
I wrote a lengthy PM but apparently it didn't send... Hmmm
Anyway, If you'd be interested in making a few coins I'd really appreciate someone who knows what they're doing rebuilding my Q-Jet. I just brought home my 81 and it's running really rich, to the point of having fouled plugs. I'm going to go through the whole CCC manual, but a fresh carb will make a good start. If you're interested, please reply with your address and what you need from me to start. my email is ec928nc AT hotmail DOT com. Thanks.
I have built a few of these carbs for forum members but it seems, most, including the first one I started the thread about, were sold to people with "project" cars that never happened.
This has been a bit frustrating for me because I wanted people to use the carb and report on it publicly. Also, I always explain to people that I put every carb I build on my own car and test drive it before I ship it to them. That means the carb should be installed and used fairly soon, not stored for a few years, while the residual fuel in it turns to varnish.
81Batmobile has used his and commented on it. I did build a couple for forum members recently, one of which was for GerryLP, and I know his car is roadworthy, he just has not had a chance to install the carb yet. hopefully we will hear from him soon.
God bless, Sensei
P.S. I am not accepting any new carb work right now, but I would be happy to advise anyone looking to do the work themselves.
What a coincidence!
Just today I was swapping the carb on Gail with one I had Sensei modify for me. And all I can say is WOW!
The only adjustment I made was the idle, for I have a XE-268H in her motor, and prefers 600 RPM in drive over the stock 500 RPM.
Clumsy me, I leaned on the EGR Bleed Solenoid, and cracked the plastic manifold onto which the EGR hoses hook. So I had to glue it.
But then later, I took Gail for a spin, and one unexpected improvement over my Vette stock carb was the ease with which I press the pedal. It almost feels like a new car in that respect.
Another thing I noticed is that she has more pep -she spun past 3K RPM like nobody business, and the seat of the pants feel was much improved.
On my lap around town, I placed the transmission in 1st gear, and about 3,800 RPM's I noticed she didn't want to switch gears when I placed the stick on 2nd, But I dis not re-adjusted the TV cable travel thinking that it would be the same (this replacement carb is an L81 carb. In automatic, the tranny functions fine.
So tomorrow I will adjust and go for a 4th of July ride. I should be able to report back soon.
Chris, thanks for the gasket. It save me time away from the auto parts store.
GerryLP :cool
most of the time all these carbs need is different secondary rods to richen up WOT. that is the change that GM made between Q jets for SBC vs BBC
