Greenie
I never heard of such an antiquated system! What a joke if its true.
I'm with you, no NAV for me. I will not be taking any long trips or going places that I don't now with the C6 anyway!LongTimer said:Now that we've seen the way the radio on the NAV works - touch screen with no SW controls - count me out for NAV. I'll take the 6 cd indash physical buttons I can select while keeping my eyes on the road. Anyone besides me see the irony of offering the best HUD in production, but forcing the driver to look at a screen to make radio adjustments?
Well, I looked for an "Im with stupid" icon, but couldnt find one.c4c5specialist said:HI there,
Directly from GM service information for the 05 Navagation section......
To use the player as a single music CD player, you must first remove the Navigation map DVD. While playing a CD in the CD/DVD Player, the navigation system is not available. The message "The disc installed is not a map DVD" will appear on the display if any of the Navigation hard keys are pressed.
Allthebest, c4c5![]()
First, lets start with this. While the single DVD is inside the player and functioning, you cannot listen to a CD. There is only 1 DVD.
The reason for this is the voice recognition(VR) system within the navigation unit. Obviously, if there is background noise like from music, it will not work correctly. You do NOT have to use the touch screen, voice prompts will work better for the safety of you and your occupant.
The system use a GPS transponder to access your position, and references vehicle speed from the PCM to also track location progress.
In order to use the navigation voice recognition, you must install the DVD and press the AGREE button to start the VR session.
Once this done, most prompts to the entire system can be used, without taking your hands off the wheel.
I hope this quells the debate.
Allthebest, c4c5 :eek
c4c5specialist said:Well, I looked for an "Im with stupid" icon, but couldnt find one.
While I was in BG, I was completely educated on the NAV system and function.
There are 2 slots in the NAV unit, one for the DVD and one for the CD. You CAN play the CD while the NAV is working, however, it will be muted when using the VR or voice recognition system for commands. This will enable handsfree usage of the system.
Now, also, the NAV will be displayed, for the most part in the HUD. I saw this first hand, and all I can say is that it enabled you to NOT take your eyes off the road, and drive confidently.
Sorry for the inaccuracy here, my bad.
Now, as for the indash 6 disc changer, it will not be available with the NAV unit, however, CGA(Corvette Genuine Accessories) is working on engineering a 6 disc changer that will be mounted in the right rear storage compartment to work with the NAV unit.
c4c5specialist
This is an exerpt from a dealer post on another forum:c4c5specialist said:HI there,
Also, CGA is working on a six disc changer that you can install as a dealer option for those who might want a CD changer with the NAV system.
