timme69680
I am in the middle of my frame off on my 74', the first thing I am working on is the rear trailing arms. I had to replace the spindles (screwed them up pulling the old ones), BOTH spindle holders had chips right by the seals so those too, basically everything except the trailing arm and caliper holders are new.
I purchased the spindle setup tool and installation tool. I must have tried every single shim on each trailing arm assembly (dry of course). One of the spindles the setup was very tight, the other slightly looser (bigger spacer). Dry they setup and measured in spec. However, once I used the installation tool and installed them (packed with grease and followed the instructions to the T). I can barely turn the spindle, I mean barely. I only torqued to 100 lbs, not the 120 lbs the factory manual says.
Is this correct? It does not seem right to me, I am afraid it might burn up the bearings (could be a year before I get the chance but that is no reason to skip on it being correct).
