productpedler
Is there any advice or instruction on un-hooking the smog pump and lines on an 82 L-83?
Advice? Yes, don't unhook it. You'll gain nothing in terms of performance.
What about just taking the belt off. Wouldn't that be a little less strain on the engine and maybe give it a little boost. You know how when you kick the AC on, it drags it down a little.
John,Nope. The A.I.R. pump consumes about 1/8 hp; lots of other factors are responsible for the existing level of performance (compression ratio, ignition timing and advance, carburetor or injection calibration, vacuum leaks, EGR calibration, factory catalytic converter restriction or plugging, etc.).
I said without getting into the engine/BLOCK, but what about going to a set of different heads? Possibly a intake manifold?Since you ditched the emission stuff, might as well loose the cat and ECM. Put on a regular Qjet and distributor. Get your initial timing up to as much as your engine w/ tolerate and curve your dist. so that mech. advance is all in around 2,500 to 3,000. Without cam and higher CR, that's about all I can think of. Make sure your coil and plug wires are good. My $.02
Nothing I suggested got inside the engine.
