Vibration
whipperdecon
Canada
1977 Bright Red Coupe
I have a 1977 Vette that was purchased this past March. I have been feeling a vibration when between 30 and 40 miles per Hr. I have just replaced all tires , and this did not fix my problem. You can feel the vibration through out the car and in particular , in the steering wheel . I sure would appreciate any help you might have with this matter.
Pete pete@joyessence.on.ca
Welcome to the Corvette Action Center......have you checked all of the U-Joints and Front wheel bearings?
Pete,
Hopefully this thread will get the attention of a moderator and get moved to the C3 section where it will get the right attention. Your vibration is very likely a U-joint or wheel bearing as Daryllawman has suggested. I chased a vibration on my 81 for a long time and turned out to be a loose(worn out) front wheel bearing.
Welcome to CAC!!!!:CAC
good luck finding your problem and enjoy the forums!!!!!!!!!
welcome to the cac:w :w :w :w :w :w Billy
Wecome to the CAC, you will find lots of help here.:w :w :w
Thanks very much Guys , looks like I have some work to do .
It's doing quite well thank you.The suggestions have been a big help .Once again ,thanks to all that have replyed.
Pete
That Vibration
Welcome to CAC!
I found the Fan Clutch bearing was well on it's way out. Replacing this has helped, however I do still feel a slight harshnes but not having driven a Vette before I may be over reacting. Pete
