WEAR ON REAR TIRE
CHARLES
BOSSIER CITY LA.
1998 torch red coupe
Can someone tell me why i can get only about 12,000 miles out of my right rear tire it always wears out in the middle of the tread , while the outside could have as much as 3/4 of tread left . NO TIRE SPIN EVER , i am the only one who has driven it. pressure is kept at 28 psi cold 98 TORCH RED COUPE;help
CHARLES
BOSSIER CITY LA.
REAR TIRE WEAR
FACTORY WHEELS, SAME SIZE THAT CAME ON CAR FROM FACTORY GOODYEAR EMT RUNFLATS
vett boy
Florida sometimes Maine
2008 vert 6M silver
Your a little light on air ,It should say 30 psi cold on the door .Second for max tire life camber should be 0 degrees.If you can find Old Dog send him a PM for the spec.for max tire life.
I got 33,000 on my factory set and this second set hopefully will hit 40,000 plus.
navy2kcoupe
West Central FL and SE Mass.
2000 Navy Blue Coupe A4 Z51
Check out http://www.davidfarmerstuff.com/ .
He has alignment checks for the do-it-yourselfer om his website, and you might be able to get a handle on what your problem is from those.
Andy :w
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
Well,If it's waring in the middle of the tire,and it is the Correct Wheel and Correct Tire it has to be over Inflation!!! No Alignment Issue will ware just the Center of the Tire!!What are you using for a Tire gage???(I use a Quality Digital Gage)If you are using the Tire monitoring system in the "DIC" in the car that is probly your problem,it is only as good as when it was calibrated!!Over Inflation will ware the Center and Under Inflation will ware the Inside and Outside!!! Under Inflation can make them Over inflate on a long run because of Heat!!!Factory calls for 30 lb regular driving conditions and 35 lb Competitive or High speed Conditions!!!This is something I have Experimented with on my personal car,I run my tires at 33 front 31 rear and get even tire ware across the tire,and after about 50 miles I have 36 all the way around!! If I run 30 lb all the way around,I have 39 front and sometimes as much as 42 in the rear (Dew to Heat)!!! I also have changed my alignment settings from factory settings(I don't need a bunch of + caster,I rarely drive over 140 anyway!!) to L front 6 deg + caster, 0 deg camber, R front 6.20 deg + caster, 0 deg camber, 1/32 tow in Lt rear 0 camber, R rear 0 camber, 0--1/64 tow in!! This will alleviate Bump Steer and Scalloping of the inside of the front tires,and get Optimum Tire ware! "WARNING" This will make the car a HANDFUL above 140 MPH!!!! :upthumbs
Lilburn GA
2002 Yellow Z06 (sold); 1999 Pewter FRC (sold)
That was my thought too.
Get a good gauge and double check the TPM- it just might be off on that tire.
