69396Chevy
Ok I have a 68 verty with a 350 with reall crappy heads. Looking to put some aluminum heads on it but not really sure what I should get in the means of specs. Its a 4spd with a Holley 650 carb and here are the cam specs. lemme know what you all think! cnpgalea@yahoo.com
Basic Operating RPM Range:
2,000-5,700 RPM
Intake Duration at 050 inch Lift:
218
Exhaust Duration at 050 inch Lift:
226
218 int./226 exh.
Advertised Intake Duration:
278
Advertised Exhaust Duration:
284
Advertised Duration:
278 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.462 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.470 in.
0.462 int./0.470 exh. lift
Lobe Separation (degrees):
112
Camshaft Gear Attachment:
3-bolts
Intake Valve Lash:
0.000 in.
Exhaust Valve Lash:
0.000 in.
2,000-5,700 RPM
218
226
218 int./226 exh.
278
284
278 int./284 exh.
0.462 in.
0.470 in.
112
3-bolts
Intake Valve Lash:
0.000 in.
Exhaust Valve Lash:
0.000 in.
