aboatguy
- Joined
- Jul 1, 2005
- Messages
- 424
- Location
- Slidell Louisiana
- Corvette
- AI head/cam/intake, Vig converter, D44, EM LTs etc
For those that own WBO2 systems what are you using?
What are you trying to accomplish.For those that own WBO2 systems what are you using?
On 95s you don't burn chips, just reflash them with software and a cable. I wanted to add decent A/F readings to my dataloggingWhat are you trying to accomplish.
Do you have the ability to burn your own chip or are you looking to buy a stand alone digital wide band system..
Well I can assure you that the cheap narrow band systems will not get you their.On 95s you don't burn chips, just reflash them with software and a cable. I wanted to add decent A/F readings to my datalogging
Mike
So which one do you have?Well I can assure you that the cheap narrow band systems will not get you their.
One of the cheaper wide band is the LM1 but I have no experience with it.
I suspect that it's popularity is due to the low price rather than outstanding quality.
Here is a link you can check out
FJO Enterprises Inc. - WideBandO2.com
The system that I have cost about 30 times what a LM1 would but like they say you get what you pay for.
For just some fuel adjustments then remove it the LM1 may work for you.
I have 2 systems that work simultaneously.
The system that I use to just visually watch what it going on is from this site
DynoTune - DynoTune-Nitrous systems, Purge kits, Nitrous Bottle heaters and more!
The system that actually controls the fuel and spark and is used for data logging is Accel Gen. 7 with wideband .
