Paul Higg
I spent the day removing the radiator and cleaning it. I found a veritable forest in there. I had the FSM to guide me but some of those little 10 mm screws on the shroud, well, they were tough. Also, removing, and what's worse, replacing the shroud! What a job! Now it looks like I might have a tiny leak from the lower transmission nut. I shouldn't lose too much fluid as I didn't lose a lot when I disconnected them today and then I might use high-temp teflon tape. Any better ideas? Definitely not cross threaded at least.
Anyway, I also replaced the engine coolant temp sensor and test drove it for a while. I now have a 30 degree drop in temp from the day before and it is the same ambient outside temp too. What a difference.
