Mad-Mic
Gone but not forgotten
here is my dream setup running thru a pro built 700R4 with 4000 stall still on IRS with a dual stage 200-300 shot with a mini ram ported to the max setup on a BIG single blade TB running DFI
[SIZE=-1]
they make a 675 chp setup also.
http://www.shafiroff.com/ultrastreet/472_675_engine.asp
drop in bolt up and go
- Dart Tall Deck Iron Eagle 4Bolt HP Block with Raised Cam & Splayed Steel Billet Caps
- Callies 4340 4.250 Stroke Internally Balanced Crank
- Eagle 4340 H-Beam 6.125 Steel Rods w/ARP Bolts
- JE 10.5-1 Custom Forged Aluminum Pistons
- Brodix 11X Aluminum Heads w/CNC Chambers
- Dart CNC Ported Intake Manifold
- Ultra Street Big Dawg Polished Aluminum Valve Covers
- 1.6 Ratio Aluminum Roller Rockers
- Moroso Street/Strip Oil Pan, Oil Pump & Pick Up
- Chrome Timing Cover w/ Tavia Pointer
- HP Harmonic Balancer
- Internally Balanced
- Professionally Blueprinted and Assembled
- Every Engine Dyno Tested w/Dyno Sheet Provided
