srs244
on my 78 pace car...i have this unusual problem and wonder if someone could help me out (or has experienced the same at one point and can provide an answer).
my car is a weekend cruiser. as such, it doesn't start with the first turn of the key usually. when i turn the key, the engine cranks and assuming that it doesn't catch, i release the starter and retry. after the second try (and sometimes after the first try), the car appears "dead". there is no starter response...not solenoid "clicking", absolutely nothing in the way of starter response. i know that there is battery power as the dash powers up and after switching the key on and off, jiggeling the ignition lock, pulling and reinserting the key, and just about everything else i can think of to try except hitting it with a hammer (trust me the thought has occurred to me more than once, lol) if often (but not always) will activate the starter and i can get the car started. it also seems that as long as i try to restart the car again (after driving it a bit) within a reasonable time frame (like early the next morning after putting the car up around 9pm the night before), the starter activates on the first turn of the key. however if the car doesn't start and i release the starter position on the ignition switch, very often, i get the "dead" response on the next turn of the key once again. i thought of the neutral safety switch, but the starter can eventually be activated without ever fooling with the shift lever (the car is an L-48 automatic), and i have tried shifting to neutral from park and moving the shifter a bit while trying to crank the car to see if there was a bad neutral contact, but that doesn't seem to be the problem as i can often (but not always) get the switch to engage the starter eventually by fooling with it as previously described without ever changing the shifter or playing with the neutral switch.
before i start buying replacement parts, i would love to figure out what exactly to buy (i've already got a great stockpile of extra parts, lol). is it the ignition switch that is going bad (or has gone most of the way there already)?? if not, what else could it be. what should i look for or check out??
thanks for the help.
steve
steve
