Work around for driver seat replacement problems - C6Z06
  • Thread starter Thread starter Z06_505
Z
Z06_505
I am a new member to CAC . I have a 2006 C6Z06 and have been tracking it since last May. I want to further the experience by replacing my OEM seat with a competition seat and adding harness and harness bar. I have read on other forums that removing the OEM seat renders the SIR system inoperative as well as the power telescoping steering wheel. There may also be DIC alarms. I have not seen a solution to these problems, but suspect one similar to the CAGS eliminator resistor could be done or has been done. Thought I'd check with this group to see if someone has figured out a work around solution.
The power and performance of the C6Z06 is unreal and I need the additional upgrades to keep myself planted in the seat.
Here are passing highlights from a recent event at Sebring. (11min-42 meg)
http://home.insightbb.com/~c6z06/SBpass.wmv
Thanks....:beer
Thanks....:beer
Hi there,
The solution is to install the harness bar and the 5 point harness AROUND the stock seat.
It is pretty simple, as long as common sense is followed.
DO NOT HINDER THE LEFT SIDE BOLSTER AREA, FOR THE SIDE IMPACT BAG.
That is the underlying rule.
The stock seat is very supportive and works very well on aggressive maneuvers.
The 5 point harness is the key.
Correctly installed with the harness bar, you will NOT hinder the seat operation, keep the air bags functional and all you have to do is install a latch to the seat belt buckle.
Allthebest, :bash
