rockers>>
The 1.6 rockers will help slightly...the reduced friction being the biggest help.
Unless you have nice cylinder heads (IE
orted and polished, or larger runners) you won't see the benefits like you would installing a high performance cam. The reason is that most of the benefits from an aftermarket cam is in the increased duration and valve overlap.
On stock heads, at .500" lift with a 1.94" valve, the heads are usually flowing as much as they can. Opening the valve further doesn't really increase the air flow because it's not the valve that's the choke point anymore. But open it earlier and close it later in the cycle like a performance cam does and the longer duration will allow more cylinder filling at higher RPM for more power. This coupled with the valve overlap (not to be confused with Lobe Separation Angle, although they're related) which also increases high RPM breathing is why a performance cam helps power.
The 1.6 rockers will only increase your lift. They do have a minor affect on opening and closing times of the valves since the valves will open and close more quickly, but this is fairly insignificant.
But you do lose alot of potential valve train friction with the full roller rockers (especially important on the closing), which will allow you to increase your engine RPM by about 500.
So the whole thing I'm trying to say here is don't expect a SOTP improvement after you install them, but rest assured that your engine is sliding free as a bird.
You might even experience a cooler running engine because the oil won't heat up as much in the rocker pivots.
-Dave C. '97 Z28
PS: "roller tipped" rockers, IE rockers with a roller tip but a pivot ball fulcrum, are pretty useless. The friction in a rocker is at the fulcrum. The LT4 uses full rollers, and I believe the LS-1 uses roller fulcrum, slider tipped rockers which are good.
