1988 Question on code
muddywaters
wilkes-barre,pa.usa
1988 white 4+3 coupe 99 Torch Red 6spd. coupe
Hi, My question is, on my 88, pulled it out of hibernation , got a code 34, checked connections at maf/map, still get code, what puzzles me is that after it reaches operating temp. the SES lite is gone and doesn't come back until next cold start???? Any ideas???? I love this site, it takes the uble out trouble shooting...............Thanks
vetteoz
Not in Kansa anymore
Work through the diagnostics
MAF code 34
"A Code 34 could be set for several reasons as well.
A bad ground, an opening in the ducting between the MAF and the throttle body,incorrect minimum idle-air setting of the throttle body,
or a worn throttle body can all cause a Code 34.
Typically, a worn throttle body or a bad ground will set a Code 34 intermittently
