BlueCorvette
I have a 1985 with the Z51 option. I have the suspension disassembled and was thinking of changing the shim position to lower the car about 3/4".
The rear seems simple, just move the shims from top to bottom and you're done.
I read that you can just remove the front shims. Does anyone here have experience with that?
Looking at the rubber shim assembly on the front leaf, it doesn't look like it was designed to be messed with or disassembled. It looks like it was put on the leaf as one unit, sliding from the end and then stuck in place.
Also, doesn't the spring need room to flex up and down in the crossmember. Would taking out the top shims affect that?
