greengrass_6
New member
Thanks, guys. It worked just like you said. I had a bit of trouble with the fob, and I tend to break things when I'm having to force them so I was being careful. Still, I've got both doors open and boot and bonnet held open so nothing closes till the battery is charged up again. Then it's off for a run, maybe to Dover or Brighton, sunshine or no. After that I'm going to Brooklands, the first ever banked track in Britain to cruise round the museum there. Going to make up for those stressed days.I just recd your thread and it looks as though you've been answered. Yepper....your FOB had a key inside it. Remove and go to rear of car, look under rr fascia and find key slot/lock. Unlock trunk (bootlid). Inside trunk look left (inside) qtr panel and find wire with tab on end. One for door and one for gas door. I wanted to mention that on (Mid-America I think is where I found this) they sell a cable set that will connect to bty and will allow you to connect trickle charger and also also allow you to connect power if suddenly goes dead. You dont really have to have it though.....it's just a convience item by have the cable already stowed under there and has diode to prevent backflowing power. good luck![]()
Thanks again, good job.
Greengrass
