Finally appear to have fixed power door lock
Glen Burnie, MD, USA
1986 Bright Red Coupe
Way back when, I mentioned that the passenger side power door lock wouldn't lock all the way by the switch- the 'orange' would be gone, and it would look locked, but you could still open it from the outside (or sometimes just half-open the door). If you manually pushed the lock, it moved another mm or two and all was fine.
Had the door apart today to fix a flapping trim strip and decided to take a look at it. Almost looked like the actuator wasn't pulling the lock bars far enough. I noticed, however, that the arm from the actuator snaps into a small metal swivel plate (technical term :) ) which has the rod going to the lock mechanism itself also attached. This plate has two holes in it, a lower and an upper. The lower hole is where the actuator rod was attached. On a hunch, I moved it to the upper hole (involves sliding out the rod end and pushing out a plastic "keeper" that's in the hole). Now works like a champ! My service manual doesn't appear to go into enough detail to explain the plate, but the lock works so I'm not complaining...
[RICHR]
vigman
Motor head!!!!
Valencia, CA,USA
Good news
And you didn't break the nylon thinggy... extra points 4 U
Vig!
D
Drewser
I'm dyin here!
Oh such technical terms like metal swivel plate and nylon thingee...OYE!
The metal swivel plate thingamajig is called a "bellcrank" and is used to swivel 90 or 180 degrees usually.
The nylon thingee is called a linkage rod retainer and used to be made of metal (on older chevys) but the plastic has shown to be MUCH easier to work on, for me anyway. BTW--I have several different "thingees" from various makes and models if you happen to need one.
I knew that opening cars for a living would come in handy here. I'm no engine expert but I AM a lock expert and know more than I need to about doors and steering columns.
--Drew:w
Mad-Mic
Gone but not forgotten
Annapolis Maryland
1987 Redskin Red Coupe
Re: I'm dyin here!
--Drew:w
Repo Man???? :L
D
Drewser
Re: Re: I'm dyin here!
Mad-Mic said:
Repo Man???? :L
Uhh---maybe once or twice. :D I usually get ahold of the cars after the repo hacks have...hacked them up.
