Art Jett said:That's correct. If you look at post # 2 by Bill 75 it shows the mounting points pretty clearly.
Art
dshanks said:Thanks, its all making sense now. I was having a hard time seeing them on the photgraph at first, but now that ive seen the part off the car, it makes sense.
Thanks everyone, problem solved!
Bill75 said:I lightened up the pictures a little
Bill
Jack said:IMHO, the OE cast iron-steel one that looks like this:
http://corvetteactioncenter.com/forums/attachment.php?attachmentid=10592&d=1151373327 ... looks like Bill's & Ralph's
... is the best one to use ... far sturdier than the OE stamped bracket on earlier C3 ... and the aftermarket adjustable "headermount" brackets are junk. I've gotten em out of junkyard ... IIRC, got one set off a GMC pu truck.
BTW ... it will not work well with motors that have the earlier cast driver side exhaust manifold because that manifold has the lower bracket built into manifold.
Derrick,
I just put headers on mine and used all the original mounting brackets, didn't have any issues with headers, mine is a 75 and might be different but here's a couple of photos. A little hard to photograph but I'll be happy to take a different angle if it helps
Bill
Wonder if you would mind posting the pictures again.
Thanks,
Bill B
