maxrevs85
I use the stock rad, with 180 stat Fans on at 205 off at 180...... I bought a Stewert alum pump when I did my rebuild. very good pump and not expensive.
Edmond said:You've got the natural air thing going, just like me.We don't need no stinkin' AC.:L
rrubel said:Bah. You young'uns... when it's 95 degrees with 95% humidity and I'm stuck in bumper-to-bumper traffic, I offer SACRIFICES to the guy who invented car A/C. I NEED MY COOLTH!
Which reminds me - if all goes as planned, I'm going to replace my A/C seals this weekend and fill up with Freeze-12. My mechanic is going to drain the last of the R-12 tomorrow.
[RICHR]
vetteboy86 said:Ideally you would want something inexpensive.
Installing larger capacity injectors (OEM 24 lbs/hr to 30 or 36 lbs/hr.) results in:
Plus: it is more reliable.
Minus: in L98, LT1 '92-93 there is little or no gain with a batch fire injector system (it works better with SFI, '94-01), it requires recalibration of the PROM or PCM, too big a jump may cause problems at idle or at specific points on the curves, it costs more.
