VetteVirgin
I just ran across this CU block on ebay, item #220522271191.
My problem with it is that the assembly date is Feb 6 (which matches the 5675 vin) but the casting code is Apr 1? Is the D11 possibly NOT the casting date?
If this block is correct it is less than 400 off my 61's vin which is closer than I ever expected to find, but if its just a restamp I'll keep looking.
If I wanted to go the restamp route, I think I would just buy item #360183861934.
Thanks for any input you can provide!
DT
Note: After inspecting the photo again, the "D" may actually be a "B". There is definitely the outline of a "B" within the lines of the "D" if you look closely...
DT
JM .02
