TheSearcher said:Get the hi-performance key fob - adds 10 hp at speeds over 180mph.
very funny! :L
avacorvette said:My battery whent dead over storage. had to reprogram the radio and found out the key fobs don't work. The owners manual tells you how to reprogram the key fobs (2-11 :confused i think) but my auto trunk opener on the key fob does not work. I will try tonight to reprogram. Anybody else have this problem????
avacorvette said:I just got a recall on the steering wheel lock yesterday. Called up C Harper(Bell Vernon PA) Chevy last night and they will be done with it today. I wll ask them about the key fob and let every one know..
[SIZE=+2]FOB Programming and synchronization[/SIZE]
Once you replaced the battery, try the following before you buy a new fob. Howver, most of the time, the fob needs to be replaced.
FOB not working is a common problem. The FOB transmit the RFA signal to a receiver in the car. The receiver is the same one used by the Tire Pressure Sensor. The receiver could be bad if there was a problem with the tire pressure monitor system. If the TPS works fine that point to the fob. Check if you have any codes in the RFA module.
You can try to reprogram. There are two type of programming. 1- Is synchronizing. Hold lock and unlock button at the same time for 20-40 sec. The horn will beep. 2- Reprogram with the DIC.
You can try with an other fob. Or ask a C5 buddy to give you his fob for a test. You reprogram and you see if the fob is really the problem.
Here is the programming procedure in case you need it.
Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next .Repeat this step for each transmitter.
Terry Holtz said:On e-bay there are plenty of fobs for sale for 2001 to 2004 Vettes. Two... a pair .... of the fobs can be had on e-bay for $28.50 plus $5.50 for shipping.
For some reason 1997 to 1999 are much more expensive. The only one I can see on e-bay is USED and is going for $56 dollars ... and there are still three days of bidding left.
