JLMICCA
I have a '63 convertible with a hood alignment issue. The front edge of the hood sits about 1/4 inch above the headlight panel. There are no shims to remove under the hinges. The Corvette assembly manual mentions adding shims to raise the front of the hood but no incite on how to lower a high hood at the front. Is this a sign of accident damage? Can it be adjusted in any way? I mentioned it to a Corvette mechanic who said his only repair was to cut the hinges and reweld them shorter. It would see this would cause interference issues when closed. Any help out there?
