I have changed a lot more since I replied on pg 2, the only stock things on my car as of now are the spindles, the glass and the mirrors. Everything else has been modified in some shape or form.
Twin turbo smallblock w/ 5 stage dry sump system but soon to be 598CID BBC w/ 5 stage dry sump system (and maybe 2 turbos in the future)
ZF 6 speed transmission w/ TH400 yoke, custom mount and working on forced oiling/cooling system
Custom flip front
Custom flares w/ bucket lights in the works (L88 style)
Custom front & rear suspension w/ full coil overs, home built lower control arms, fully adjustable uppers, home built rear suspension fully adjustable also. Rrear suspension geometry changed, front geometry remained stock apart from adjustable upper ball joint to increase kingpin height for increased camber gain.
Wilwood Integra 6 & 4 piston calipers
Hydaulic hand brake (home built)
Custom cooling equipment w/ fluidyne radiator, remote C&R thermostat housing w/ recirculators, uses Volvo style thermostats, fluidyne oil cooler and remote oil filter adapter w/ adjustable bypass (to oil cooler) valve, uses HP6 style filters
3 PC. Modular aluminium/magnesium wheels w/ 295/50/16 tires on the front and Hoosier Pro street 31x16.5x16s on the rear
10 pnt rollcage from S&W race cars, upgraded to 12pnt w/ swing outs on both sides
Custom aluminium fuel tank (working on that one)
Appleton front end take off steering rack setup
Custom interior w/ sheet alu dash & console, all autometer ultra-lite gauges (12 of them)
Modified & reinforced frame w/ custom rear subframe and reworked front end (for coil overs), reinforced in a lot of areas and completely welded through.
Rebuilt differential with polished internals (to withstand cracking but hoping on getting a C4 D44) Rear end cooler & remote filler
Custom exhaust, full stainless.
Relocated battery (cut off battery boxes)
Custom rear light setup (4 brake lights)
Custom side markers (looking for some small led bars)
Custom side gills, a combination of enlarged 80/82 style gills (no inserts) and an additonal hole in the fender.
2x SX fuel pump + billet filters (pre and after), aeromotive a2000 boost ref. press. regulator.
All CV products pulleys & drive mandrel
Powermaster mini alternator
Tilton XLT mini starter
KRC power steering pump
Patterson 5 gal oil tank
Raceline remote oil press. regulator
custom IRS:
rollcage:
custom IFS:
frame notched for coil overs:
Front flares cleco-ed on custom flip front end
rear custom flares
removed battery/storage boxes for custom IRS
overall picture of the mess in my shop
