Vettepirate
Not the typical questions here.
Im just being frustrated by the oil plug which seems to be stuck really tight. Does anyone know what number wrench i need to take it out? I even tried using vise-grips and it wouldnt budge! I cant use a socket wrench because theres no room between the plug and the frame just behind it. I also dont know which way to turn it, since i fear it might be one of those freak bolts that requires you to turn clockwise to unscrew it. Since i dont have a hoist, and i refuse to pay a ridiculous amount for an oil change, Im bent on doing this on my own.
Im afraid that ill strip the bolt to shreds if i try the grips again, the bolt isn't doing that well right now but im hoping the right size wrench might do the trick, i just have to find it first and apparently we dont have the one i need. After that, ill use the magnetic plug i bought and ill leave it loose enough so i dont need a hammer and a 2 foot lever to take it out the next time around.
Who thought an oil change would be so complicated.. then again im sure having a hoist at my disposal would solve a lot of problems. As i dont have one, the elbow grease is being put to use... hell sometimes a job like this is way more satisfying when youre done anyways
