wishuwerehere82
- Joined
- Sep 6, 2003
- Messages
- 2,316
- Location
- Rochester, NY
- Corvette
- Red '82 Coupe,Sebring Silver '98 Coupe
Bob,
The shaft does not come out of the pump. Your Melling pump will have a new shaft coupling with it. Snap the old (orange)one off the extension and put the new one on.
Remove your distributor to aid in installing the oil pump. If the notches don't line up, you will have hard time getting the pump to seat and possibly break something. Then rotate the pump shaft until the distributor lines up with the pump shaft and drops back down.
When inspecting your bearings, you will see a tab on each bearing that fits into a notch in the cap and block. If the tab is missing, the bearing has been spinning. You will see scoring on the crank surfaces if it has spun. Hopefully, all will be well. Get some Plastigage from your auto parts store and measure your bearing clearances one at a time. If they check out OK, clean off the Plastigage then retorque them and move along until all bearings are inspected, measured.
Keep it simple. That's my motto.
