Power window return spring install - advice?
  • Thread starter Thread starter Gator81
G
Gator81
I've got to replace the coil spring in the power window unit of my driver's side door. I ordered the spring, but it came with no instructions. I'm sure I could blunder my way through it and figure it out, eventually, but I figured somebody on here has done this and can tell me what not to do....
Must the window motor be removed from the door? What's the best way to tell when you have the proper initial tension on the spring?
