M
MerlinC4
Hi All,
I have a set of rear flares that I'm planning to install soon, but I don't have much body work experience so I don't really know the proper order to do things. First, I plan to chemically strip all the paint, then I'll install the flares. Here's my current plan:
1. Strip the body completely.
2. Mount the flares with screws to see where they'll sit, then remove them to cut out the old fender lips.
3. Remount the flares with screws and glue them on with Vette panel adhesive.
4. Use a stranded fiberglass body filler to smooth the flares into the body.
5. Use a more lightweight filler for the final smoothing.
6. Epoxy prime the whole mess to see how things look.
Does this process make sense, or should I be using other products or a different order of steps?
Thanks in advance!
Thanks in advance!
