Help! Reduced engine power
carltonoverton
New member
TX
2002 z06 torch red
I have a 2002 Z06 throwing codes out left and right. Says no comm. it’s an off and on problem. When I disconnect the battery for a while everything starts back working. Please help
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
Moving out of the Site Help and Feedback forum and into the correct C5 Tech forum...
Delta98C5
Jefferson Parish, LA
stock 98 C5 pewter 145K miles
Were you able to solve the issue ? You only have this one post so we'll probably never hear from you again! This happened on my car . Although the battery had 12.2 volts that was the problem . Hopefully you got it fixed
Danny Boy01
LaSalle
Nice how they only put up one post to ask for help then disappear into cyberspace with no thanks or even a reply...
Sent from my iPad using Tapatalk
carltonoverton
New member
TX
2002 z06 torch red
Yes, I solved the problem. I would be happy to share what I discovered with the c5 Corvette, at least the 2002 model
carltonoverton
New member
TX
2002 z06 torch red
If you remove the battery and look down below, you will notice your PCM sits directly under the drainage that comes from condensation when running the air conditioning. I designed a tray that i mounted to the firewall that re-routed the water away from my PCM. No more problems, this was months ago. Not saying you have the same problem, but my c5 was showing all these alerts, reduced engine speed-service traction control- abs light and more, since i installed my home made re-router tray i have not had any more codes. My email is carltonoverton@live.com
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
I got a novel IDEA,Why don't you clean the crap out of your udders and you won't have to do any modifications…… https://www.corvetteactioncenter.com/forums/c5-technical-and-performance/98731-corvette-udders-anyone-have-pictures.html
