carltonoverton
New member
I have a 2002 Z06 throwing codes out left and right. Says no comm. it’s an off and on problem. When I disconnect the battery for a while everything starts back working. Please help
I got a novel IDEA,Why don't you clean the crap out of your udders and you won't have to do any modifications…… https://www.corvetteactioncenter.com/forums/c5-technical-and-performance/98731-corvette-udders-anyone-have-pictures.htmlIf you remove the battery and look down below, you will notice your PCM sits directly under the drainage that comes from condensation when running the air conditioning. I designed a tray that i mounted to the firewall that re-routed the water away from my PCM. No more problems, this was months ago. Not saying you have the same problem, but my c5 was showing all these alerts, reduced engine speed-service traction control- abs light and more, since i installed my home made re-router tray i have not had any more codes. My email is carltonoverton@live.com
