- Thread starter
- Moderator
- #161
Toms007
Moderator
Too wet, cold and nasty to go work on the Vette tonight. Tomorrow is supposed to be a much nicer day, so I'll get those injectors changed then.
Yeah well Tom,stay in the house,must be a full moon!!Too wet, cold and nasty to go work on the Vette tonight. Tomorrow is supposed to be a much nicer day, so I'll get those injectors changed then.
Yeah well Tom,stay in the house,must be a full moon!!For some Freaking Reason,My 94 has started acting up Big Time!!Has thrown no codes,Won't Idle below 1100 and fluctuates to 1675,Shows 24.8 V sometimes Ignition voltage on the scanner,TPS voltage fluctuates from 0.92-1.26 back and forth at times!! Went and got a new TPS at Chevrolet,still does the same thing!!I guess it's time to start checking all the grounds,either it's developed a bad ground somewhere,I've popped a diode or my ECM has took a Crap!!! Alls I did was decide to clean it up a little bit and change the spark plugs!!
:bash
:bash
Junk don't you remember. If it ain't broke don't work on it.
Guys I have not read all the threads on this post but it crosses my mind that you are changing out the plug to see if it is suspect and the same with the injector has anybody done an ohms check of the plug wire and wiggled the wire at the connectors to see if you have an intermittent short.
Junk, isn't that the way things go? If you need a new ECM, I have one (a new reman'd unit) for a 6 speed.
John, I think you may have hit part of the nail on the head. After swapping the #8 and #1 injectors I have improvement. So I think I must have had a questionable connection. I am going to check Ohm readings on, at least, #8 plug wire. I guess I am too hard headed, because I kept thinking they are less than a year old and not that many miles. :eyerole But I need to check.
Have checked the resistance on the plug wires???:confusedI know what your talking about though!!I've been driving my 94 for about 6 months and 5,000 miles just because no body has been looking at it on the lot!!Now I get someone interested and she decides to be like my wife,CanTankerous!!~!!Here's what I got done today.
I took her out for a little test drive.....bad news really no different than before, so I let her cool down a bit and swapped Bosch injectors for the OE, no change. So I let it cool down again and run a compression test. All cylinders(hu hem except #6 which I couldn't get the tester started in) between 150 and 160.
So I have got a trailer and I will be hauling it to the mechanic who is going to look at it this week. I'm tired and frustrated and I just want to drive my car, I guess this one beat me....I just hope that the mechanic will figure it out in a timely manner.
Tom,call the place that you bought it!!I think it has a 12 month 12,000 mile warranty!WEll just got off the phone with my mechanic....My Opti is dead on 1 1/2 cylinders and sometimes 2 1/2. One cylinder is missfiring and half the time, #6 is dead all the time and one other will die on a half regular basis.
Why wouldn't this thing set a code? So where is the best place to buy a new opti...my Genuine GM didn't last 6,000 miles. Thinking seriously about an MSD. I don't know. I need to do something tonight.
I have heard some good things about the MSD unit. Too bad the beautiful red color of the cap is virtually hidden once the unit is installed.
Keep us posted!
SAVE THE
Well Tom,I'm glad your luck is going better than mine!Well I got the MSD opti today....wow, this baby is well made. It also comes with the hoses to make it like the GM engineers should have made it, vacuum hoses to tie into the intake and out of the air intake hose in front of the TB. These things are really well made.....I guess they ought to for $515.
