9340Ruby
I have a 1993 LT-1 with 55,000 original miles.  What do you all think about changing the spark plugs and if so what should I use?  What is all involved in changing the plugs on an LT-1?  Thanks for the help in advance.  BK
I own a auto repair shop 32years. My advice is to use only ac delco original equipment plugs. I have had a few later model GM products ping ever so slightly after changing plugs. All of these were cured by installing the original plugs. My thought as to why is as follows. These plugs were designed and engineered for your engine. What I think happens is other plug manufactures cross reference the originals and say hey we have a part # here that will work and market it for your application, but they may be slightly different in heat range, gap ect. Todays modern engines are dialed in pretty tight and it doesnt always pay to deviate to far from what was designed for your car. Just my personal opinion, but I have had no tune-up comebacks since adopting this policy. Good luckThanks. I was really interested in the process. It sounds like a job! BK
Iv'e done this on my ruby three years ago - make sure you get some type of plug grease for the plugs since it is a aluminum block and heads - I used a regular spark plug socket with a open end wrench that can be used on it and Yes its a tough one. MAKE SURE it threads correctly - there is nothing worse than a cross threaded spark plug in a aluminum head - I had one playing games but after a little clean up it threaded fine -Good Luck
I have not changed the plugs in my 93 yet with 90K. I have a question for those who have done the job. It seems to me that on the back plugs a socket with a 3/4 hex on the end would work with a wrench on the socket. I have been looking at Harbor Freight and they have a set of ratcheting offset wrenches that would fit the hex on the plug socket. Would this work?:crazy
I support the AC 41-906 although my last set fouled pretty badly.
I only pull the drivers side inner fender panel; only 5 10mm bolts
#s 1 and 3 I get with a 10 inch extension and a u joint through the panel opening and under the AC compressor.
#s 5 and 7 require the EGR hose and the ASR to be undone and pulled out of the way.
#s 2 and 4 are conventional and ez to get to.
#s 6 and 8 I get from under the car.
I would never attempt this without a reasonable tool set.
Enjoy,
Perry
Snap On tools makes a socket for the tough to get to plug. It's advertised as a "Muscle Car" plug socket made for cars with headers. It's a short socket with the center drilled out so the tip protrudes and it has a 5/8 6 point on the end for an open ratchet or a wrench. It's well worth the $27 and Snap On is the only one I've ever seen that makes it. I have two of them, one for the tool box and one for the trailer tool box.
