vms4evr
I've got a few questions regarding mixing suspension parts...
I have the base "soft ride" suspension on my92. The car has 90K on it and it is all original suspension parts.
1st - I'm looking at the Bilstein Sport shocks. I think the car comes with ones listed as HD. The Sport are supposed to be more aggressive. Part # 1177 and 1178 at VBP.
2nd - Considering thicker sway bars. Like 32mm front 26mm rear. Maybe a little smaller.
3rd - Replacing a bunch of the rubber bushings with poly on the front and rear. Some of mine are rotting out and squeezing out. So I need to replace them with either new rubber or go to poly.
Now I'm getting mixed feedback on what happens when I do this. Without changing the FE1 springs are the Bilstein Sports a bad idea? I'm confused as to why the shocks would be so bad.
On the sway bars I got very different opions. One side said they will make the car flatter period. The other side says no way. The car will handle worse than stock by using the wrong shocks and thick sway bars.
I'm no suspension guru so could you folks give me some opinions and explanations of why or why not on those changes.
Thanks, Graham
Thanks, Graham
