Gail is running warmer than usual, and I can't seem to figure out why..
She runs at 200 degrees after warm up, but after a while, she develops some sort of heat soak, and the gage climbs to 230, 250, and ever closer to the red band.
She was doing this with her stock carburetor, and still does it with the re-placement carb I had Chris do for her. Tonight, I took a look closer at her fan and clutch, and it seems to be ok -checks out fine IAW the shop manual.
Now, you guys may be tilting your heads ever so slightly and thinking, "whatchoo talkng bout, Willis?"..."most late C3's do get hot all the time in the summer", but Gail has her Heavy Duty radiator that came with her trailering package, and I have never had a problem with her gage rising as it does lately...and no, it is not a bad gage or sensor...for years, I used to wonder if her electric fan worked, for it never would turn-on, but now, it regularly is turning by the time I get home (as it happened today when coming from work).
So, W.T.H.??? What am I missing? Help is greatly appreciated
GerryLP:cool
I think that it is also causing her hard start in the morning. She acts as if there is no fuel in her carb tank...again, the same with two different carburetors. So, it almost seems as if the heat soak is evaporating the fule from the carburetor tank.
GerryLP:cool
ad
  ARF-ARF !
