JrRifleCoach
This problem has been haunting me (and others) for years; The vette rear end will drift right when you lift off the throttle. This is most noticeable when traveling downhill at 45-55+MPH. If you reapply throttle, the car will now drift to the left.
It must be remembered that the suspensions of these cars vary in condition. Mine is completely rebuilt with the best parts. Others are DD's or weekend cars with high component times.
The only one parallel I can draw on is the rear toe. One suggestion was that the rear spring may not have equal amount of pressure on each side.
Any of your thoughts are appreciated. Even the satrical. (I may regret that)
I'm almost ready to call Gordon......$$$$$
