02-TR-Z06
I removed cleaned and re-painted the drivers side Valve cover.... I don't know where to begin to remove the other one. I think it would be easer to pull the engine.
Any advice??
Any advice??
:eyeroleI removed cleaned and re-painted the drivers side Valve cover....
TopDown94 said:...I AM SO CONFUSED:confused Go back and read the post on this subject. It started with the wrong valve cover!!
JT ZR-Won said:If you loosen the altenator bracket so you can move it out of the way a bit, it you should be able to wiggle it out of there
Jay
Chris McDonald said:Riko,
That sure is a bright red car.
I have done this trick a few times. It is going to be hard to describe via this format, but here it goes.
First, you will need to drop the serpentine belt and disconnect the battery for saftey. there are four (10mm hex head) long bolts that go from the passenger side towards the center of the car that hold the a/c compressor to the bracket. You may need to remove the center inner fender skirt section to gain clean clear access.
Pull the A.I.R. valves off the upper bracket and slip the A.I.R. hoses and tubes off from the manifold pipe up. Pull the throttle body heater hose off at the throttle body and the rear coolant line off the intake.
Next, (13 or 14mm) bolts-yours could be torx head to remove the E.G.R. tube from the manifold. Be careful here and use some good penetrating oil. In fact, you should put the oil on before you start the whole job to give it time to soak.
Don't worry too much if you wring those bolts off, you can drill out and replace with a bolt and nut.
Use a torx to reach under the distributor with a long extesnion and remove the intake manifold side of the E.G.R. tube.
Okay, now you are ready to pull the valve cover bolts and wiggle and jiggle until you get it out.
NOTE-it is not always neccessary to take all these steps just to pull the cover. However, yours will be freshly painted and you don't want to force it back in as it would scracth off the new paint.
Now reverse the procedure.
Hey, better you than me.
I hate doing this job. I have also changed the valve stem seals on the car on 3 different C3s. You talk about standing on your head and juggling tools all Saturday afternoon. Two of those times I also painted the covers since I already had them apart.
Good luck.
Good luck.
JT ZR-Won said:So how did they turn out?
Jay
