Glide
- Joined
- Jan 23, 2007
- Messages
- 118
- Location
- Charles Town, WV
- Corvette
- 1971 Shark, 1985 C4, 2011 C6, 99 FRC. 66 Coupe
Dad gumit! Had the project vette all tuned up with Platinum plugs, cleaned the throttle body and new brakes and rotors all the way around. Just set the idle and the damn bottom falls out! Anti-freeze everywhere. It got on the belt so I can't tell where it's coming from but once it heated up, it was coming out fast and the radiator was gurgling.
I suspect the water pump case the hoses appear good but I've never seen one go that bad or that fast.
If it is the water pump, does NAPA make a good replacement and would this be a good time to remove the air pump? What is involved in that? Thanks!
