Dad
- Joined
- Nov 18, 2001
- Messages
- 611
- Location
- West Unity OH
- Corvette
- 15Gray/8sp 72Blk/Blk4Spd 64Red/Red/Wht4spd
I’m in the engine rebuild mood and have some questions of the learned folks out there.
First off it’s a 350, 1978 vintage, big valves and 4 bolt mains. With the bore of 4.00 and stroke of 3.48 to get the 350 C.I.D., the question comes to mind that with the new pistons with the offset pins it would seem like the displacement would increase by the distance the pins move up. As an example, if it were .50 longer stroke (throw of the crank would have to change) the C.I.D. would increase about 50 C.I.D. or 400 C.I.D. total. I would also think that the lower drag pistons and rings plus the lighter powdered metal rods hooked up with the better bearing they are using today would give you more and quicker RPMs.
Here is my problem, the ZZ4 has the offset pins and the latest pistons and should have the latest in bearings, rods and rings. The data I have still lists the bore and stroke as 4.00 X 3.48. What am I missing here? With a price of $4500 for the ZZ4 you would think they would take advantage of the extra cubes unless they can’t swing the crank. If nothing else they can swing a 3.75 stroke that was used in the old 400 which would add at least another 27 cubic inches. The mains would have to be bored .200 oversized and that may be the draw back.
I haven’t built an engine for 14 years and the task of getting the extra cubes is looking like more than I want to tackle.
Lay it on me, what has been going on out there in the engine rebuild world and is this doable?
;help
;help
