- Joined
- Jan 1, 2002
- Messages
- 7,243
- Location
- Washington, Michigan
- Corvette
- '67 Marina Blue Convertible
Dad -
Jack did a great job on the numbers - as he mentioned, some rods and/or rod bolt heads need some clearancing depending on their forging profile - all of which needs to be done during trial-fitting, BEFORE balancing.
For a street engine, I think the "light pistons/low-tension rings" hype falls in the same category as the "5.7"-vs.-6" rods" hype; you'd need NASA-level laboratory instrumentation to tell the difference. Using a 400 crank in a 350 block for the 383 and keeping the 5.7" rods, the pin location in the piston only moves up 1/8".
