69MyWay
BigBrakeFuelie said:Hey fellow Shark owners,Sorry to but in on the post.I`m also in the process of buying a new engine.I found a 383 Stroker for $2095.I`m also considering a Crate from GM performance products it`s a 350 cubic in 330hp,at 5000rpm.380ft.lbs of torque at 3800rpm. This one goes for about $2400.
What engine would be better for my car? I`m just looking for a fun ride with good street usable horsepower.Reliability is important too.
Sounds like either one would be fine. It would be more fun to bench race and brag about the 383. Plenty of torque, and plenty of go power with inexpensive bolt on mods.
been reading throu your post and think everything I read might gest be over kill for what you want out of your vette acording to the post you made on 10-06. the parts that you have aquired thus far for a 383 stroker are a good start for a 1/4 bracket drag car. they will give you knight mares on the street and if your wife has to drive it she wil tell folks that you suffer from young mail motcho isuess desese :J ? unless you would like to go through the prosees of building a engine by your self it is not econmicly wize to engineer and build one your self. there are to maney realy good crate motors on the market and all the engeneering has been done . take the 383 Vortic truck motor that is being offerd by GM put a 750 holley with vacume secondarys and some Hooker super comp headers, keep the 308'S and opp for a 700R4 with a 2800 stall tork converter and keep the lockup . from stop light to stop light the 5.0 stangs and Lt1 comeros won't be abel to out pull the torqe of the 383 roller moter once you get your foot out of it to hook up your tires becase with the 2800 stall it will break the tires at will. If your getting on the freeway and you want to put the hammer down and you have the fotatude to ceep the pedal on the floor the 700 will shift down, on its way to a lowergear it will lett the engine rev to about 47-4800 and bang into gear. it will be all you can do at this point to ceep your back tires from passing the front ones. as far as top speed goes with the over drive and lock up i bet you won't want to go that fast in a 72 vette roadster even with the top on. and you could expect to get 18 to 20 mpg out of it. now you won't beat Waren Jhonston in the 1/4 but you will get respect and yor wife will like to drive it. so put that stroker kit on Ebay and build your self a modern rod .
